Hi, some times the bpm changes on its own. By example: 2 songs are playing, both on 115 bpm. Then after a few seconds both songs are playing at its original 128 bpm... Without even touching the pitch en adjust anything.
Is anyone familliar with this and know an solution? now happened to me for the 5 time.. really annoying...
geposted Mon 11 Jan 16 @ 12:38 pm
Is the setting (from Settings->OPTIONS) ControllerTakeovermode in Pickup ?
If its in Instant and your controller faulty sends midi messages from the Pitch fader, then they could move instantly.
geposted Mon 11 Jan 16 @ 12:43 pm
controllertakeovermode and controllertakeovermodepitch is both: Pickup
geposted Mon 11 Jan 16 @ 12:46 pm
Any chance your controller has a button that resets pitch ?
Several controllers have this function and you could be firing this by mistake or the controller could be faulty triggering this button/message.
So, which controller do you use ?
geposted Mon 11 Jan 16 @ 1:11 pm
using an gemini CNTRL-7
to reset the pitch it is twice touching the pitch button. But with no touching the controller at all and just listen to the songs it changes..
has it maybe something to do with the controller? like a faillure in the sound card or something?
Thanks for your quick reaction though
geposted Mon 11 Jan 16 @ 1:15 pm
