Topic: default folder options "Move to..."
Hi,
Its been months im trying to find a way to solve this.
Im doing a lot of bpm editing this last weeks and have created other folders for newer edited files.
The thing is that every time i want to move a file to those new folders it keeps continuously leading me to "desktop" folder.
wich is very annoying because i have to go all the way through the path to finally put the file in its new folder.
I looked through browser options but cant really find what would be the option to change.
The only way to bypass this is to put all folders in desktop (with vdj) but i already have lots of files and it takes a while to transfer.
i have windows 7 home, virtual dj 8
Thanks for your help :)
Ps, i've found another post about this, sorry i didnt see it before.
https://virtualdj.com/forums/202879/General_Discussion/retain_last_folderpath_when_copying_moving_a_file_from_virtualdj_8_(windows_10).html
geposted Thu 14 Jan 16 @ 3:28 pm
Just mark all the files, press and hold Shift key and drag and drop the files to a folder on the left browser part.
Works like cake :)
btw, "shift-drag" makes a copy of the file
"ctrl-drag" moves the file
Thanks pachN
Hello. I have just tried shift+drag and drop and the result is file moving not file copying. I have tried ctrl+drag&drop and the result is file copying. Thanks.
So it might be a windows option somewhere.
mine moves with "ctrl" and copy with "shift"
however, it does the opposite while on windows browser...
