Hey folks I'm trying to stop using OTS AV and I have an infinity license been and have been an owner of VDJ for a very long time. But stopped using it when it failed me years ago. Now it looks like it's a more mature product and I'm learning it slowly. I'm mainly a wedding Jock so my I'm more of an automix kind of guy especially when I'm on the floor. Here is the deal I love the Mixlab Skin but it appears to not have a fade now to the next deck button like some skins do such as Oranejuice. I'm wondering if I'm missing something, I know on some skins you an create a button with the command embedded. I also know I can set up a keyboard short cut. But I would kind of like a button if there is one in Mixlab can someone let me know or is there a way to add a button into the skin. Thanks in advance for any help that you might have.
geposted Wed 20 Jan 16 @ 2:14 am
Are you using version 7 or 8?
The Mixlab skin is very old now but there has been an update for version 8 below. It doesn't have any custom buttons on it which are supported in V8 and would solve your issue.
https://virtualdj.com/plugins/?addonid=80084
geposted Wed 20 Jan 16 @ 3:39 am
I'm using VDJ 8 latest version and the latest version of the skin.
geposted Wed 20 Jan 16 @ 4:44 am
It was I who updated the Mixlab skin for VDJ 8...
Oh yes it does!
I did add a couple of custom buttons when I updated it. If you use the button to the right of the headphone mix slider, you can switch between 8 different panels above the mixer. The 'display' panel has two custom buttons.
Oh yes it does!
geposted Wed 20 Jan 16 @ 6:00 pm
I couldn't see them so thanks for the info.
geposted Wed 20 Jan 16 @ 6:25 pm
First let me say great job on the update. Second I wanted to say thank you, I found the buttons and will be using them. An awesome job on an awesome skin. )
geposted Fri 22 Jan 16 @ 7:33 am
Cheers! It was DJ Format who did all the hard work, with the original skin so long ago. I just updated the code.
There's still stuff that doesn't work correctly or at all on the skin - mainly due to changes in the way VDJ works.
geposted Fri 22 Jan 16 @ 6:17 pm
