Hello,i have worked with my virtual in my pc with xp sp2,now i took a new pc with windows 7,i send all my work from my old pc on my new one,but when i send it all my database is not saved,if i send it from xp sp2 to xp sp2 it is all there,but when i send it xp sp2 to windows 7 my database is not configured,can you tell me how to make that all my work will be saved while i transfer my virtual from xp sp2 to windows 7? Please someone help me.Thank you.
geposted Tue 26 Jan 16 @ 4:22 pm
Install VDJ on Win 7 machine
Check where "virtualDJ" folder is created (my documents?)
Copy virtualDJ folder from old machine and replace the one created when installed on new machine
Make sure all your music is in the same folder as the old machine
geposted Wed 27 Jan 16 @ 8:50 pm
Yes the user data has a different path in Win7 compared to xp
geposted Fri 29 Jan 16 @ 5:20 am
