I have a wav file that plays fine outside of VDJ, but when I play it in VDJ it's just a load of fuzz. I've tried deleting and re-adding the file, deleting the track info from the database, 'checking' and 'cleaning' the database from within the VDJ settings. It's still not working.
I added a bunch of other wav files at the same time and they all work fine. I'd previously renamed the problematic file, so that could be the issue. But I returned it to the original name and cleared its database info so it should be fine. Any ideas?
geposted Tue 26 Jan 16 @ 10:34 pm
what freq sample rate?
geposted Tue 26 Jan 16 @ 11:03 pm
Ah the bit rate's 2304kbps for some reason. There an easy way to change it?
geposted Wed 27 Jan 16 @ 4:54 am
i'm asking in a diagnostic sense, would you mind uploading said track to dropbox or similar to test here.
geposted Wed 27 Jan 16 @ 5:06 am
Audacity can convert it.
geposted Wed 27 Jan 16 @ 5:59 am
Here you go loco https://soundcloud.com/dub-motion/rollin-free-download
Will check that out blck
geposted Wed 27 Jan 16 @ 6:16 am
48khz sample rate, playing fine here
geposted Wed 27 Jan 16 @ 8:04 am
I guess a sample rate is not the same thing as a bit rate then.
As I said, it plays fine in everything except VDJ. I'm using VDJ7. Do I need to do anything else to remove all trace of the track from VDJ?
geposted Wed 27 Jan 16 @ 3:58 pm
DJkanman wrote :
I'm using VDJ7.
VirtualDj 7 won't play files with sample rate bigger than 44100.
VirtualDj 8 does...
geposted Wed 27 Jan 16 @ 6:25 pm
Ah that's the problem then. Cheers phantom
geposted Wed 27 Jan 16 @ 7:10 pm
