My Virtual DJ asked if I wanted to use latest version and now it gives me 'No Sound Card Initialized' when I try to use it.......?
Is it something I am doing or is anyone else having this same issue ????
geposted Wed 24 Feb 16 @ 3:03 pm
Your sound settings might be wrong.
What soundcard do you use ?
How's your sound settings configured ?
geposted Wed 24 Feb 16 @ 4:06 pm
Sound Card Initialized' Look for you Sound card then make up a name for it or use the name from card
geposted Fri 26 Feb 16 @ 2:33 pm
How do I reconfigure my sound settings
geposted Fri 01 Dec 17 @ 3:50 pm
Under Settings->Audio in VDJ
If the sound card is natively supported there will be a button named like it, that you just need to click
But if a Windows or MacOS update has messed up any sound card drivers, you may have to download them from the manufacturers homepage and re-install them
geposted Fri 01 Dec 17 @ 3:58 pm
Hello, I just got an Idance DJ for christmas and i have installed everything that needed to be but i can't press play and when it lets me it won't put out sound. I got it to work for like 2 minutes then it stopped. How do i fix this?
Thanks,
Travis
Thanks,
Travis
geposted Fri 29 Dec 17 @ 6:16 am
