Forum: VirtualDJ 8.1 Technical Support
Topic: Robo play.
I am new to Virtual DJ. I am familiar with many of the other working parts of the interface. However I used to be able to load a list of tunes in another player software and it would play deck A and deck B back and forth without me being in attendance. With a nice blend in between.
I only do this stuff at home. I am nobodies pro. I used to use PCDJ (VJ) version 5.2 I could create lists on the fly and have them play off of that list. How do I do this with Virtual DJ?
geposted Sat 27 Feb 16 @ 12:00 am
What I do when i get a new program, I usually start with the manual. I strongly suggest you do the same for any program you might get in the future.
https://virtualdj.com/wiki/PDFManuals.html
Concentrate specially when you get to the section about Automix and POI. Lots to learn there.
Please read the manual, because VDJ has an Automix function, that will work in one or both players. The Automix panel is located to the right of the browser, and looks like this,
