I'd like a button's LED to be on when the volume is 100% (and off when less than 100%). Is this possible?
geposted Wed 02 Mar 16 @ 10:42 pm
On the led mapping type this:
param_equal get_volume 100% ? on : off
PS: For this simple query you don't even have to use the on : off part
So you can also type
geposted Thu 03 Mar 16 @ 12:52 am
Great that it's possible. I've read over the docs and it looks like I need to create my own xml file for LED mapping?
geposted Thu 03 Mar 16 @ 2:59 pm
Providing that the LED is already mapped (most are), you can simply alter the script for it in settings/controllers.
What device are you using?
geposted Thu 03 Mar 16 @ 11:26 pm
A Traktor X1. I'm using VDJ7 and there isn't a controller option in config > settings. The only thing available is the Simple Midi Wrapper?
geposted Fri 04 Mar 16 @ 12:22 am
For VirtualDj 7 you will have to create a device definition in order to get leds working.
Simple MIDI wrapper does not provide MIDI output (PC to controller communication)
VirtualDj 8 supports both X1 (in MIDI mode using default MIDI template on NI controller editor app) and X1MK2 (in HID mode)
geposted Fri 04 Mar 16 @ 11:09 am
I thought so. Would you mind showing me how to do that? I've gone over the documents and past threads, but it's confused me.
geposted Fri 04 Mar 16 @ 12:19 pm
geposted Fri 04 Mar 16 @ 12:26 pm
Already found that kradcliffe. I'll give it another shot.
geposted Fri 04 Mar 16 @ 6:33 pm
I've tried different variations of this but have not got it to work. Can anyone see where it's going wrong?
I've copied Traktor X1 Mk1 mapping.xml to: My Documents\VirtualDJ\Mappers
And Traktor X1 Mk1 definition.xml to: My Documents\VirtualDJ\Devices
Traktor X1 Mk1 mapping.xml:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="SIMPLE_MIDI" author="Me" description="Traktor X1 Mk1" version="741" date="03/03/2016" priority="-10">
<map value="1-CC6" action="deck 1 eq_low" />
<map value="1-CC4" action="deck 1 eq_mid" />
<map value="1-CC0" action="deck 1 gain_relative" />
<map value="1-36" action="deck 1 level 100%" />
<map value="1-40" action="deck 1 level 0%" />
<map value="1-CC2" action="deck 1 eq_high" />
<map value="1-28" action="deck 1 sync" />
</mapper>
Traktor X1 Mk1 definition.xml:
<device name="Traktor X1 Mk1" author="Me" type="MIDI" decks="4">
<button note="C1" name="param_equal get_volume 100%" channel="2" deck="1" />
<led note="C1" name="LED_param_equal get_volume 100%" default="param_equal get_volume 100%" channel="2" deck="1" />
</device>
</mapper>
</device>
geposted Wed 23 Mar 16 @ 9:21 pm
You got it all wrong! :)
DEFINITION
<device name="X1MK1" description="Traktor Kontrol X1 MK1" author="Me" type="MIDI" decks="4">
<button note="0xC1" name="BUTTON_NAME" channel="2" deck="1" />
<led note="0xC1" name="LED_BUTTON_NAME default="BUTTON_NAME" channel="2" deck="1" />
</device>
MAPPER
<mapper device="X1MK1" author="Me" description="Traktor Kontrol X1 MK1" version="741" date="03/03/2016" priority="-10">
<map value="BUTTON_NAME" action="play_pause" />
</mapper>
DEFINITION
</device>
MAPPER
</mapper>
geposted Thu 24 Mar 16 @ 9:48 am
Cheers Phantom but I still cannot work out how this all ties together. The current action of the button is "deck 1 level 100%". I want the LED of that button to be on when the level > 0%, and off when the level = 0%, regardless of if the button has been pressed.
Note: I changed it from 100% to 0% as in my original post. It's an LED to tell me if that deck's volume's on or not.
geposted Thu 07 Apr 16 @ 9:15 pm
If your led is defined properly then the code you need to put on your mapper is:
param_bigger 0 get_vu_meter
geposted Thu 07 Apr 16 @ 11:57 pm
Eeerm... You use VirtualDj 7...
The correct syntax for VirtualDj 7 is
get vu_meter & param_greater 0 ? on : off
geposted Fri 08 Apr 16 @ 12:01 am
The button action works. As far as I know the led is defined properly?
Ok I've tried adding "get vu_meter & param_greater 0 ? on : off" to the mapper code. It doesn't work under "action", and it doesn't work on its own after map value. Where does it go?
DEFINITION
<device name="X1MK1" description="X1 Test" author="Me" type="MIDI" decks="4">
<button note="0xC1" name="1-36" channel="2" deck="1" />
<led note="0xC1" name="LED_1-36" default="1-36" channel="2" deck="1" />
</device>
MAPPER
<mapper device="X1MK1" author="Me" description="X1 Test" version="741" date="10/04/2016" priority="-10">
</mapper>
The button is set to "Note", the mode is "Gate", and LED On: For Midi Out
DEFINITION
</device>
MAPPER
</mapper>
geposted Mon 11 Apr 16 @ 1:51 am
DJkanman wrote :
MAPPER
<map value="LED_1-36" action="get vu_meter & param_greater 0 ? on : off" />
</mapper>
MAPPER
</mapper>
geposted Mon 11 Apr 16 @ 6:42 am
Cheers for your help Phantom. Unfortunately it still isn't working. Maybe the led's not defined or something. I'm going to have to play around with it some more.
Out of interest, instead of using vu_meter could I put this:
<map value="LED_1-36" action="deck 1 level 0% ? off : on" />
geposted Tue 12 Apr 16 @ 9:22 pm
This is an English only forum, thank you.
geposted Sat 23 Jul 16 @ 7:38 pm
