Question about working with the side list in VDJ 8 (latest build) . I know it is a bit different than 7. When dragging tracks to my side list, if I want to delete a track from there is there a way to just hit the delete button on keyboard like 7? Or do you have to right click then select delete? Also is there a way to have the tracks from side list removed as soon as you drag that track to a deck or do you have to wait? I set it up to delete after playing but it does not seem to be working. Thanks for any assistance
geposted Mon 07 Mar 16 @ 9:00 pm
Yes, you can hit delete.
If you have the removePlayedFromSidelist option at yes, the tracks will disappear automatically, but only after the time specified in the historyDelay option. That is the amount of time a track has to play before being recorded in your history (in seconds)
geposted Mon 07 Mar 16 @ 9:12 pm
Thanks for your help. I am using a Mac Book Pro and latest VDJ8 and hitting the delete button on my keyboard does not remove the track. I have to right click and delete through that menu. Hmm.
geposted Mon 07 Mar 16 @ 9:36 pm
Ah, some of the Mac buttons don't work the same as Windows. I seem to remember maybe you need Cmd + Delete or something like that ....
geposted Mon 07 Mar 16 @ 9:58 pm
On Mac: Option + Delete will remove from lists
geposted Mon 07 Mar 16 @ 10:10 pm
Thanks All for the help!!
geposted Sun 13 Mar 16 @ 6:36 pm
