So I have a pioneer DDJ-SR and i am using VDJ8. I know my mixer has 4 decks and VDJ picks up on that, but since its 2 channels, i cannot figure out to utilize deck 3 and 4. Atleast i am sure it has 4 decks because its got buttons that switch between. Are there any settings that i can change in VDJ to allow me to play audio from deck 3 or 4? I would really love to be able to do so. Any advice would be helpful.
Thanks!
Thanks!
geposted Mon 14 Mar 16 @ 5:55 pm
geposted Mon 14 Mar 16 @ 6:25 pm
The Audio Setup shouldnt be a problem (since its just Master & Headphones), so all u have to do is to choose/load a 4 Decks skin.
But even with the 2 decks skin, you should be able to get sound out of decks 3 and 4 and control them as well, since the 2 decks skin is based on left-right selected logic.
One thing that you need to know is that you may have to pull the Volume faders down first when u change/swap decks. Thats a Hardware/firmware feature.
geposted Mon 14 Mar 16 @ 6:51 pm
Thank you for the advice. I did not realize i had to pull the volume slider down then back up. This indeed did work.
geposted Tue 15 Mar 16 @ 12:59 pm
