Hello. I have noticed that "mix_now" action is not the same "mix now" in drop down menu when right clicking on song in automix list. Let's say automix is on and a song is playing. I want that to mix the song that is selected in playlist not the one that is in the next position. Like when I select a song in automix list and right click then mix now. Can this be done by mapping a key ? Thanks.
geposted Tue 15 Mar 16 @ 7:24 pm
using a mouse to select the song ? then just double click it (instead of one click, then push a button... double click is faster).
geposted Tue 15 Mar 16 @ 7:48 pm
automix_skip
geposted Tue 15 Mar 16 @ 7:55 pm
Auto_mix will mix the next song on the list, but let say I need to mix another song on the list, how I will mix selected song, not the next song on the list?
geposted Tue 15 Mar 16 @ 8:24 pm
Yes, you're right. I want to map a key to double click action :) I have mentioned the drop down menu because there is a " mix now" option wich is not the same with the mix_now verb.
@djdad: automix_skip is not what I want (mixing the next one in playlist). Let's say I have an encoder. I want to use it to scroll through songs in playlist and when I push it to mix the song that is selected not the second song in playlist. Thanks.
geposted Tue 15 Mar 16 @ 8:31 pm
In that case, a new action is required. Please post your request to the Wishes Forum.
geposted Wed 16 Mar 16 @ 2:07 pm
Not sure how it happened, but lost all sound on my 3,4 decks. Have 3 shows this weekend. Any help?
geposted Wed 16 Mar 16 @ 4:38 pm
Please don't hijack threads, open a new thread and help will be available.
geposted Wed 16 Mar 16 @ 4:48 pm
Thanks, I will.
geposted Wed 16 Mar 16 @ 5:20 pm
