]The bar signal its alwals touching the red part ,how can Bringing to normal ,I play vinyl timecodes, I check cables are ok
Im using console RMX 2
Mac late 2008 2.4 GHz
geposted Wed 16 Mar 16 @ 3:00 am
On 8.2 still the problem wich never got answer
geposted Mon 13 Jun 16 @ 8:31 am
Also is super sensitive el timecode en 8.2.
geposted Mon 13 Jun 16 @ 8:32 am
Have you tried to recalibrate your timecodes ?
Open Config, Click on "Timecodes" icon and then hit the "Calibrate" button for each timecode input.
See if that helps.
See if that helps.
geposted Mon 13 Jun 16 @ 8:50 am
Yes I did ,and also I change my rca cables from my technics turntables ,this sensitive is more noticible in vdj 8.2 and the bars of signal are aways hitting the red,what could be?
Im in mac
Im in mac
geposted Mon 13 Jun 16 @ 4:27 pm
