Hello good morning.
I have 4 decks in my controller in Vdj pro 8.
A gusset activates deck 1 or deck 3 and another gusset actives deck 2 and 4, depending on the deck I want to sound.
On a plate on the left deck, I want to activate the HOT CUE 1, giving the corresponding button on my controller and also I want to activate with the same button, the right deck HOT CUE 1; ie, activate the same HOT CUE on the left and right selected decks with the same button.
How would the command: "deck left select hot cue 1 & deck right select hot cue 1" ? I've tried thousands of ways to put a command and they does not work out either.
Thank you very much.
Do you know how?
Do you know how?
geposted Thu 24 Mar 16 @ 10:37 am
deck left hot_cue 1 & deck right hot_cue 1
geposted Thu 24 Mar 16 @ 1:09 pm
I does not work
geposted Thu 24 Mar 16 @ 6:59 pm
It works absolutely fine here. Obviously I'm misunderstanding what you want.
The script I provided above will trigger hot cue 1 on the left deck and right deck at the same time from a single button press.
geposted Thu 24 Mar 16 @ 9:43 pm
