On my Pioneer SX2, I would like to script to a sample pad: Mute while pressed.
geposted Fri 25 Mar 16 @ 4:03 pm
Mute what? The master output? The sampler?
geposted Fri 25 Mar 16 @ 4:05 pm
Mute the song that's playing. Like using the effect AutoCut, but I want to trigger the cuts myself. I don't use the Sample Pads for samples. I map them to effects.
geposted Fri 25 Mar 16 @ 4:38 pm
If it's simpler to map than yes, mute the master output.
geposted Fri 25 Mar 16 @ 4:41 pm
I got it. It doesn't sound smooth at all. Thank you.
geposted Fri 25 Mar 16 @ 4:48 pm
I mapped it to Audio Cut8 with length 1/2 and it sounds great.
geposted Fri 25 Mar 16 @ 4:57 pm
Have a try with the slip brake8 effect, playing with longer pause lengths, and tapping on and off in durations shorter than the pause length,
Might give the desired result,
Or
Or
deck x mute while_pressed
geposted Fri 25 Mar 16 @ 6:16 pm
