In the old version of vdj. You can set the beat skip to 1 button of ur choice in the config page. How would i do that in vdj8.
geposted Thu 31 Mar 16 @ 2:43 pm
Try the beatgrid FX.
geposted Thu 31 Mar 16 @ 2:53 pm
Im aware of that. But i had a different way of doing it in old version. Where i would set the skipbeat value to +1 on right key and-1 on the left. It enabled me to chop ot perfectly. With a hit of a key stroke. But there is no skip beat in the new version?
geposted Thu 31 Mar 16 @ 2:58 pm
It should still be there, check the mapping and look for what button(s) it/they are.
geposted Thu 31 Mar 16 @ 3:05 pm
Yeah i went into config. I searched to find it. I dont see skip beat.. I see repeat and some others bit no skip beat
geposted Thu 31 Mar 16 @ 3:09 pm
Seek+1
Seek-1
Or use "goto +1"
Seek-1
Or use "goto +1"
geposted Thu 31 Mar 16 @ 3:17 pm
Does anyone else have difficultly adding music to their virtual DJ folders? I recently updated to a Mac Book Pro. I am trying to load my music onto Virtual Dj and add songs to my individual folders but for some reason its not saving the songs I'm dragging from my external hard drive.
geposted Thu 31 Mar 16 @ 10:52 pm
What format is your external hdd? Ntfs? exFat? Fat32?
geposted Fri 01 Apr 16 @ 10:41 am
like CHOP AND SCREW with the music SLOW ? if so I tried it with key lock off and it didn't sound like Dj Screw sound.
geposted Mon 04 Apr 16 @ 7:45 pm
