A couple of years ago someone showed me a setting or some code (I can't remember) which enabled me to change the colour of tracks in my browser that were under a particular bit rate, resulting in all tracks under 224 bit rate being coloured blue. The problem is I now can't find how to turn that off! Does anyone know?
geposted Fri 01 Apr 16 @ 6:49 pm
There is no option to turn off the color in the browser. You may add color in your browser and minimize the column or reset your color-tag:
To reset color put this script on a custom button (this will remove the color of your tracks, think about it!!)
Mark your tracks, klick on the custom button and the job is done ;o)
I agree with you. A better way would be to have an option for the browser view to keep the color-info.
greets with beats
Music234
browsed_file_color "reset"
greets with beats
Music234
geposted Fri 01 Apr 16 @ 10:20 pm
greets with beats
Music234
greets with beats
Music234
Thank you Music234...It worked like a charm...FLeX
geposted Thu 07 Apr 16 @ 12:49 pm
