Hey mappers. We are here to help each other, right? When I press a key for a sample I would like the master volume to cut out until the sample is finished playing without holding down the key. Any help would be very much appreciated ..
geposted Mon 04 Apr 16 @ 4:39 am
I think it is not possible with shortcut.
You could add it to a skin.
something like:
sampler_play ? deck 1 volume 0% & deck 2 volume 0%
The master_volume will also mute the volume of the sampler, so you will need to use the deck volume.
something like:
geposted Mon 04 Apr 16 @ 5:16 am
Still new to mapping. How do i had it to the skin?
geposted Mon 04 Apr 16 @ 11:52 am
If you want I can help you with it.
Wat skin do you use?
If it's a special one, you can mail it to me or else you tell me what skin you use and I can download it.
Best regards,
John
Best regards,
John
geposted Mon 04 Apr 16 @ 4:14 pm
Put the script on a custom-buttom. Why edit a Skin for this ?
geposted Mon 04 Apr 16 @ 4:31 pm
Then you tell him the script...
geposted Mon 04 Apr 16 @ 6:44 pm
Custom button doesn't work..The skin i use is controller by dennyo 2 deck top wave blue & yellow...If you can, I would also love the folder icons to have a different color, like green. when you kill the bass by way of a custom button, under the bass key barely changes color.hard to see. need a brighter color like red.. Any help i would very much appreciate it..Thank you..Tropikvibez@gmail.com
geposted Mon 04 Apr 16 @ 6:46 pm
Now come on John, I didn't want to annoy you ...
geposted Mon 04 Apr 16 @ 6:53 pm
You don't annoy me... I think it's not possible with a shortcut and think about other options.
geposted Tue 05 Apr 16 @ 11:29 am
The Folder Icons you mean the yellow ones. Do you need a collor or just standard?
I tried the skin and created a shortcut on the custom button for eq_kill_high and it's blue on mouse-over en more blue when on.
You want it to be red when on?
That all can be done and I will work on the other things to.
geposted Tue 05 Apr 16 @ 12:09 pm
you need to map All the Sample buttons on your controller (or keyboard) as ..
sampler_pad X & deck left volume 0% while_pressed & deck right volume 0% while_pressed (where X is the sampler slot number)
Try it on a custom button
If you to trigger the Samples from the Sideview (Sampler view), then there is no way to achieve this.
If you want to modify existing sample buttons on a custom skin, then you need to edit the skin.
geposted Tue 05 Apr 16 @ 10:05 pm
Thanks D but i've already achieve that. I don't want while_pressed function. More like a gate or a duck function. When the sample is playing i want the main audio to cut out and come back after the sample has finished without me holding down the key. Maybe it's not possible.
geposted Wed 06 Apr 16 @ 12:12 pm
