Hi could anyone advise on how to stop effects & instruments showing up in my filter folders i.e. I have a filter folder to show tracks without a track number but it also shows anything that's in my Sampler folder as well. (also in other filters like missing genre, year etc etc)
As far as I can see there is no option to remove the sampler folder from the search database so I'm a bit confused as to what to do !
Thanks in advance for any advice offered !
geposted Fri 08 Apr 16 @ 9:21 am
You can add and file type is not .vdjsample to the end of your filter folder script to eliminate samples from appearing in that folder.
geposted Fri 08 Apr 16 @ 2:26 pm
Hi Thanks for the reply,
I tried that but still getting the same as before.
What I have as a script is : 'isscanned = 0 and file type is not .vdjsample' which looks correct to me ?
geposted Fri 08 Apr 16 @ 5:32 pm
This one works for me - isscanned=0 and file type is not "vdjsample"
geposted Fri 08 Apr 16 @ 5:51 pm
Many thanks - works perfectly now.
Much appreciated.
Much appreciated.
geposted Fri 08 Apr 16 @ 7:34 pm
