Topic: Controller can't control Virtual DJ
Hi!
I have Virtual DJ 8 and Numark Mixtrack Pro (on the list of supported devices). I can't controll with controller but only with keyboard and mouse. When i go to Audio Settings\Card there is Mixtrack PRO listed but when i go to Settings\Controllers there is only keyboard listed. How to solve this?
Thanks for help. :)
geposted Mon 11 Apr 16 @ 4:08 pm
Will work with pro license
But it should work for 10 minutes.
oh i see soo i need pro version for controllers, tnx.
Not true. The controller should be seen by VDJ regardless.
It should be possible to connect and use your controller for 10 minutes, as a trial or demonstration.
You would need a license to use the controller permanently. For home use, buy a Plus license. For pro use, buy the Infinity license or the monthly subscription.
Even if i don't have pro license, there need to be controller on the list on the Settings/Controllers instead of just keyboar listed?
- try a different USB cable and/or a different USB port
- try it on a different computer and/or a different Application (there is a chance that the unit is damaged)
- Clean the USB History (google for USB History Cleaner, USBolivion or similar), restart PC and try again
- Read this article (could be a Logitech product that could conflict with the generic Midi Driver) https://virtualdj.com/wiki/midinotdetected.html
- Last choice, if you desperately need to make it working, re-install Windows, it will take a couple of hours but will save you from days trying to make it work (don't forget to backup your files)
Many thanks man
Tomaž Novak
Did you solve your problem ?
