Hi, I am going to buy a second hand pioneer xdj r1, but it has no virtual dj le cd with it. Would I be able to download it in order to use the controller .
Many thanks
Many thanks
geposted Wed 13 Apr 16 @ 11:13 pm
Hm..I'm impressed, Rekordbox DJ support added, and positive guidance when using VDJ 7, or 8.
Things are looking up.
http://www.pioneerdj.com/en/support/software-information/xdj-r1/#virtual-dj
Use VDJ 8 so as to have the benefit of the vastly improved sampler, plus many more improvements.
I recommend using a Akai APC Mini to supplement sampler, loop, and cue point control.
I put a suitable mapping in this forum which might help.
Quote:
Downloading VirtualDJ LE 8
1. Access the website of Atomix Productions. https://virtualdj.com/le/
2.On the displayed page, input the serial key printed on this unit's bottom panel, then click [OK].
3.Download VirtualDJ LE 8. You can find the latest version of “VirtualDJ LE 8”. Click the Windows or Mac icon to download the file depending on your computer.
It's a very good piece of equipment, although a little big for a true mobile DJ.
I would also recommend upgrading to VDJ 8 Full.
Access to the vast array of addons for VDJ 8 is vital for best performance.
Good Luck.
Good Luck.
geposted Thu 14 Apr 16 @ 12:17 am
