When I type in my license code in it says that it is already in use. The product is brand new fresh out of the box. What can I do?
geposted Fri 15 Apr 16 @ 10:32 am
Contact the manufacturer of your controller (I'm assuming it's a LE version of the software supplied with a unit). It is them that issues the serial numbers.
Alternatively if the software has previously been registered you could take that up with the retailer as that shouldn't happen with a brand new item.
geposted Fri 15 Apr 16 @ 10:34 am
thanks
geposted Fri 15 Apr 16 @ 10:50 am
