I'm looking for beat aware type scripting assistance. I'm trying to.....
1) Press a button on the downbeat then have the key move +1 on every beat for 7 beats then reset to key 0 on the 8th beat to create a build up. I'll also create one to move the key -1 in the same way.
2) Press a button on the downbeat then have the volume cut in and out on every ¼ beat until the button is pressed again.
3) Kind of hard to explain this one so bear with me.... Press a button on the down beat and have the pitch speed up equally and key +1 on every beat for 7 beats then on the 8th beat have the pitch and key reset to it's original value to create a combination build up.
Well, that does it for this round of requests. If anyone has any cool beat aware scripts PLEASE feel free to share. I've seen some that locodog (the scripting guru) has put out there and plan to experiment with those in the near future. Thank you in advance for any help on these scripts.
geposted Sun 17 Apr 16 @ 4:17 pm
Hi,
Maybe the beatgrid fx is an option?
It's in addons for vdj 7 but I tried it on 8 and it works.
https://virtualdj.com/addons/14716/_VST__BeatGridV2.html
geposted Sun 17 Apr 16 @ 4:33 pm
1) Press a button on the downbeat then have the key move +1 on every beat for 7 beats then reset to key 0 on the 8th beat to create a build up. I'll also need one to move the key -1 in the same way.
3) Kind of hard to explain this request so bear with me.... Press a button on the down beat and have the pitch speed up equally and key +1 on every beat for 7 beats then on the 8th beat have the pitch and key reset to it's original value to create a combination build up.
geposted Mon 18 Apr 16 @ 9:56 am
Thank you djjb for your response. I didn't think about using beatgrid. That might work for the third request. Maybe using beatgrid in conjunction with 'get_beatpos' & 'key_move' scripting might work. I'll have to mess around with it.
geposted Mon 18 Apr 16 @ 10:17 am
https://virtualdj.com/forums/154572/VirtualDJ_Plugins/_Echo_Out__Plugin.html
Look at this thread it will explain the fundamentals, as for request 2: use audiocut8 plugin.
geposted Mon 18 Apr 16 @ 4:18 pm
