Hi Dj's ;) I have a question to you. How to do to save BPM's? My program scanned my files a long time yesterday and today don't remember that and I must scan one more time. Is it the fault of the internal drive? Sorry for my poor english, I hope that you understand me. Greetings ;)
geposted Tue 19 Apr 16 @ 4:22 pm
They should save automatically in the database.
Check permissions on your Documents > VirtualDJ folder to make sure it has read/write access.
You never mentioned if you are using a PC or Mac .....
geposted Tue 19 Apr 16 @ 4:41 pm
Thanks for quick answer. I have PC and Virtual DJ FREE 7.4.7. I think it would be automatically saved. Perhaps when I disconnect the external drive to the night was made such a mistake
geposted Tue 19 Apr 16 @ 5:06 pm
Make sure you shut down VDJ before removing the drive as it writes the DB on close.
geposted Tue 19 Apr 16 @ 5:38 pm
If your tracks are on the external drive you did a big mistake, yes :)
geposted Wed 20 Apr 16 @ 9:29 am
