Hi,
I'm just about to replace my main HDD with a new SSD. I plan to do a clean install rather than clone the old drive due to errors on it.
VDJ is installed on my main drive (c) but I only use an external drive to play music from and the external drive has got a VDJ database so I know that's safe. (well assume it is anyway ??)
My question is do I need to copy anything from the main VDJ folder in 'My Documents' on the old C drive or is it a simple case of just downloading VDJ again and doing a 'fresh' install onto the new SSD.
Many thanks for any advice offered.
geposted Wed 20 Apr 16 @ 3:43 pm
database on the external drive is itact.
you do need to copy the VDJ files under My Documetns. This has all your settings, skins you use, plugins, history, playlist etc.... Better just copy the entire folder into a Thumb drive.
When finish installing a fresh VDJ, copy all from the thumb drive.
geposted Wed 20 Apr 16 @ 3:48 pm
Ok I will do that - thanks for the reply Magic
geposted Wed 20 Apr 16 @ 3:51 pm
