Forum: Old versions
Topic: Problem with p4 2.8Ghz 800
I got a problem with virtualdj trial version, the explorer hangs and you have to close it and then restart it. I think the problem is with the processor because the problem occurs when i put a P4 2.8Ghz 800FSB with 2 512mb DDR 400Mhz.
If i put a 1.7ghz celeron processor (keeping the existing ram) it does not make the problem. Is there anything I missed out? is there a problem with virtualdj with an 800bus processor?
geposted Sat 11 Oct 03 @ 4:45 pm
It's not the system bus that is causing the problem, it is your P4's Hyperthreading ability. VDJ doesn't quite like it too much. Do a search in the forums, several other people had the same problems (or similar) The suggested remedy as been to turn H.T. off. Since I have an AMD processor, I am not sure if it is done in the BIOS or within the O.S to turn that feature off in Intel chips.
Regards;
Redman247
geposted Sat 11 Oct 03 @ 10:07 pm
