Even if I have the option "Auto BPM match" to off it does change the deck pitch according to masterdeck. Why?
When pressing play on one deck will directly match the pitch slider to the other deck.
geposted Sun 24 Apr 16 @ 4:19 pm
You probably have smart play enabled then.
geposted Sun 24 Apr 16 @ 4:22 pm
Yup! That's the one. Thanx
geposted Sun 24 Apr 16 @ 4:52 pm
