Is there an easy way to take a photo and then get it straight onto the screens. Either into a slideshow or as a single frame via the sampler?
geposted Thu 28 Apr 16 @ 10:43 pm
I use DropBox on my PC, on a Mac ill use Tumbler with a QTZ file but that's with Mix Emergency and SDJ since QTZ files aren't supported in VDJ.
geposted Thu 28 Apr 16 @ 11:46 pm
I haven't tried it but what about blue tooth if your out in the crowd, instead of using a usb connection to transfer your images to a folder.
geposted Thu 28 Apr 16 @ 11:52 pm
Looks like dropbox could be the answer. Thanks
geposted Fri 29 Apr 16 @ 12:54 am
I just use a Camera and take SDcard out and transfer it to the laptop (directly into the folder where Slideshow plugin uses).
geposted Fri 29 Apr 16 @ 1:59 am
