Is there a option in VDJ to set the master output to be a mono output. I am constantly at venues where they only have a mono setup. If there is not a built in option is there a plugin that I use for Mac to achieve this effect?
geposted Sat 07 May 16 @ 9:06 pm
in audio settings select "Chan 1 (Mono)" in your master output... or even "Chan 2 (Mono)". depends if your connecting from the left or right channel.
hopefully that's what you're looking for.... :-)
Pete
Pete
geposted Sat 07 May 16 @ 11:25 pm
what does it mean to have a mono setup?
geposted Sun 08 May 16 @ 11:55 am
In most clubs, you want both channels coming out of each speaker, instead of having stereo separation. You know, left signal coming out of the left side of the room, right signal coming out of the right side of the room. You don't need that separation, because you are not in the middle of the room, as in your home. This way, no matter where you are in the club, you hear all of the music. In my opinion, I set up in stereo, and the club takes care of the mono for me.
geposted Sun 08 May 16 @ 5:09 pm
