Hello, I would like to ask for advice. When I use VDJ8 on my computer at home which is connected to the WIFI I do not need to input a password. It opens automatically. However, when I'm out of the house e.g. somewhere in a club, I connect the PC to the Internet through my phone. In this case it asks the password each time. Even when the PC is not connected to the Internet it denies to accept the password. I don't need the Internet on the party but I have to carry it with me because of this reason. Although I click "don't ask again" the result is the same. It drives me crazy and I really do not know what to do with it. Could anybody help me, please. Thank you very much.
geposted Sun 08 May 16 @ 11:06 am
If you're only using the one computer, then once you have logged in, the registration info is stored in a file on the computer.
When you run VDJ on that same computer when you're at a gig, there's no need to connect at all. VDJ will use the info from the stored file.
The important thing is not to log out. If you log out after each use of VDJ then the file is removed - meaning you will have to log in again.
geposted Sun 08 May 16 @ 11:32 am
groovindj, I know how it should work, but it's not working. I turn VDJ8 Login, Internet connection is required. When I turn off the VDJ so they do not sign, yet when restarting the abbot Check-in and license code or Login to VDJ. Can you tell me please write Where to Find the file?
geposted Sun 08 May 16 @ 1:24 pm
Perhaps 'don't remember me' is checked on the login screen?
geposted Sun 08 May 16 @ 2:26 pm
I got it for clicks
geposted Sun 08 May 16 @ 7:44 pm
