I have seen many people are using Itunes to make playlist rather than VDJ.
Just curious as to why. Also how exactly are these playlists prepared in Itunes
that make it better.
geposted Sun 08 May 16 @ 1:04 pm
It is not better, but it is futureproof. Every program for dj'ing can read the Itunes playlists, so they are available in every software.
geposted Mon 09 May 16 @ 7:17 am
Welcome to the future.
geposted Mon 09 May 16 @ 11:03 am
I could think of nothing worse. Itunes is a terrible program that keeps changing it's protocols for no reason.
It can also delete user files and all. Avoid like the plague.
geposted Mon 09 May 16 @ 11:07 am
Exactly what came to my mind reading that article, hopefully I never trusted apple, and will never ever ever do :)
geposted Mon 09 May 16 @ 11:11 am
It will "only" delete the files on a 2nd or 3rd device that is synced to your "main" apple device.
So the files won't be lost. But yes, I agree. That is just.... bad. And they should feel bad.
geposted Mon 09 May 16 @ 11:39 am
I do not use Itunes, just curious why so many do .
Always make playlists in VDJ
geposted Mon 09 May 16 @ 11:48 am
I guess it's just habit.
The database functionality of VDJ is just as good (but iTunes smart folder selection is easier) where in VDJ you have to enter the syntax manually for filter folders.
geposted Mon 09 May 16 @ 11:53 am
Agreed, stay away from iTunes. Its pretty much bloatware anymore and it breaks every other update.
Run away and run away as fast as you can....
geposted Mon 09 May 16 @ 12:33 pm
Apple music is NOT ITunes. If you didn't signed up, there is no problem at all.
But as everywhere: haters gonna hate.....
geposted Mon 09 May 16 @ 2:59 pm
Maybe I missed something here but where did anybody mention Apple Music at??
The OP asked about iTunes and using it to build playlists, nobody said anything about Apple Music.......
geposted Mon 09 May 16 @ 3:19 pm
iTunes can delete user files if you select the wrong option. It has done this to a few people I know. nothing to do with Apple Music at all.
geposted Mon 09 May 16 @ 3:26 pm
You didn't read the link posted from fruit, do you?
@kradcliffe:
that's why I wrote my post.
geposted Mon 09 May 16 @ 3:44 pm
Ahh ok, I read it.
Either way I myself recommend people not to use iTunes even With Serato they don't really recommend it even though it can read them.
ITunes was good at one point in time but now its just bloatware.
geposted Mon 09 May 16 @ 3:52 pm
then it may seen to reason to leave the box uncheck to be on the safe side
geposted Tue 10 May 16 @ 12:54 pm
ok... Itunes is not the best program. But imagine VDJ ends tomorrow, I still can use my playlists in other dj-software.
geposted Tue 10 May 16 @ 4:58 pm
@ohshit:
If you uncheck this box you won't be able to read your playlists inside other applications.
to the topic:
I build my playlists with beatunes/ITunes. or genius.
Simply because the fact I can simply listen to my sets on Iphone or other apple-devices.
Another plus are the smart-playlists imo.
Also I can use these lists then with other programs.
to the topic:
geposted Tue 10 May 16 @ 5:20 pm
the playlists vdj creates are playable in almost any mp3 application including itunes so i cant see a issue if vdj ended tomorrow :-)
geposted Tue 10 May 16 @ 7:07 pm
Correct.
I wanted to say the same.
VDJ playlists are just ordinary m3u files which could be played by almost any player.
geposted Wed 11 May 16 @ 9:12 am
