Can you sync your Dropbox music with VDJ 8? I have a load of stuff on there. I know you can drag and drop it into a new file but i see the Cloud lists options on the left menu bar and wondered if Dropbox is supported
geposted Mon 09 May 16 @ 6:47 am
Just enter your Dropbox folder via the VDJ folder browser.
Maybe make the Dropbox folder a favourit folder for faster access.
geposted Mon 09 May 16 @ 9:41 am
I personally don't do this, however a number of DJ's do and it works fine. Just remember that your Dropbox folder is a LOCAL folder which is synced TO the cloud, not served FROM the cloud.
geposted Tue 10 May 16 @ 1:05 pm
