Is it possible to have 1/2 of the screen playing a music video or karaoke and the other 1/2 of the screen showing the live camera feed? Thanks!
geposted Tue 10 May 16 @ 7:26 pm
Sure is, just download the TellyVisuals or TellyMedia plugins. Set up your screen then your good to go.
geposted Tue 10 May 16 @ 8:15 pm
I was hoping for an easier way as I have been playing with those and am struggling at putting them together. I can set up a cool layout on tellyvisuals but struggle with adding the camera feature on tellymedia.
geposted Thu 12 May 16 @ 2:23 am
Hmm not sure how much easier it can get but ill try to make a quick video tonight showing you how to do it.
Once its setup you pretty much never have to worry about it again.
geposted Thu 12 May 16 @ 4:37 pm
Thank you! I appreciate that.
geposted Fri 13 May 16 @ 4:52 pm
I was talking with Don from telly and I was told this is not possible at this time but will be with his new plugin when it is done.
geposted Tue 17 May 16 @ 7:48 pm
Hmm not true because I have 2 sometimes 3 different cameras at once with videos playing on the same screen.
You can have VDJ's video playing in a panel so if you make 1 panel half of your screen then the videos will play in that half.
Next you setup a camera and size that to fit the other half and you've accomplished what your asking for.
Maybe Don didn't understand what you wanted but yes you can have your Karaoke videos on half of the screen while a live camera fills the other half......
Here's a video I made with 3 live camera and 1 is being used as an Audio Only Visualization
You can see the other 2 camera feeds in the bottom left/right corners....... It can be done.
geposted Tue 17 May 16 @ 8:27 pm
I skyped with Don yesterday and he assured me that was not possible. He said that the camera works with the VDJ screen and it would need to be part of the video panel. When I activate the vdj music video on the panel, it pulls the camera into that panel. If I deactivate the vdj music video from that panel, I can then move the camera out of that panel to where I need it to be but then I lose the ability to play a music video. Your screen shows that it can be done but I am frustrated that skyping with Don he told me it was not possible until he releases the new NTV that will combine both TV and TM. You are incorporating both TM and TV with the screen you showed, correct?
geposted Tue 17 May 16 @ 10:26 pm
Yeah I'm using both apps.
geposted Tue 17 May 16 @ 11:50 pm
Don't be mad a Don, he is right in the sense that this can't be done with 1 app but I'm not an average user so I've tweaked the rules and combine shit until I get the desired results, lmao!
geposted Wed 18 May 16 @ 2:48 pm
Are you still able to make a quick video to show just the basics of the split screen with camera on one side and music video on the other. Thanks!
geposted Wed 18 May 16 @ 4:14 pm
Yeah I got the next few nights off so ill get something done for you
geposted Wed 18 May 16 @ 6:55 pm
Thank you. I really appreciate it!
geposted Wed 18 May 16 @ 6:58 pm
Hope that helps if not holla at me.
geposted Thu 19 May 16 @ 3:33 am
