While I am looking through my folders, is it possible to show all the songs within the sub folders? For example, I select 80's (within that, I have a sub folders for each year). Is there a way to select 80's and see all the songs contained within the sub folders? Thanks!
geposted Sat 21 May 16 @ 3:43 am
Right click the folder and then hit "recurse".
geposted Sat 21 May 16 @ 4:38 am
Awesome. Thank you very much! I didn't know what that word meant. That helps so much!
geposted Sat 21 May 16 @ 5:04 am
Is there a way to save that setting so I don't have to do it each time I open the program?
geposted Sat 21 May 16 @ 5:14 am
Naw unfortunately there is no way to do this that I know of.
geposted Sat 21 May 16 @ 11:34 am
you can just create a virtual folder and add all those songs into it.
geposted Sat 21 May 16 @ 3:08 pm
You could create a Filter within the 80s Parent Folder which, given the right parameters are used, would then show all the tracks in the sub-folders.
geposted Sun 22 May 16 @ 3:46 pm
