It's there a way to just show the video at the screen and the actual program at the computer?
geposted Fri 03 Jun 16 @ 1:47 pm
short answer ... yes,
but it would help if you give a bit more info about your set up/equipment
regards
ray
regards
ray
geposted Fri 03 Jun 16 @ 2:03 pm
I'm using a MacBook for running the Music to a VMS4... To Video I'm using a HP Windows 10 to a projector. I have VDJ 8
Pro Infinity . Let me know if you needs some more info..
geposted Fri 03 Jun 16 @ 2:20 pm
My mayor issue is to the karioke. I would like to swap songs without the people notice at the screen
geposted Fri 03 Jun 16 @ 2:22 pm
Got it.. I just checked on YouTube.. Thanks for the help
geposted Fri 03 Jun 16 @ 3:21 pm
