I am new to djing and doin it as a hobby. Recently purchased a gemini g4v controller. Switching to turntables and wanna stick with vdj.. bought entry stanton t62's.. what's the least expensive way to switch. I think I read somewhere I need to switch to the pro version.. if true, what other harware, besides mixer is needed? Thnx
geposted Sun 05 Jun 16 @ 1:16 am
First you need vdj pro
Second check if you controller have sound card(if does) your on it)
Third buy from vdj vinyl timecodes.
Good luck fella......
geposted Sun 05 Jun 16 @ 4:51 am
the least expensive would be a Maya44 soundcard(your g4v is not capable) and a mixer. But really I would think of best value, I had the maya44 and have decided that bus powered wasn't as reliable A/C powered.(for me). I would purchase a mixer with a built in 4/4 audio interface.
What is your budget...the maya44 and a decent mixer could cost $100 total. Depends on your budget.
geposted Sun 05 Jun 16 @ 2:42 pm
I really dont hv a budget. I wanna get rid of the Controller all together but not exactly sure what all I need. Was looking at the xone 23.. hv t62's alrdy and I guess I will need to upgrade to vdj pro but thinking there has to b a economical way.. I'm searching internet and just seem overwhelming. The controller was simple, plug and play
geposted Sun 05 Jun 16 @ 5:02 pm
What's your reason behind switching to turntables?
geposted Sun 05 Jun 16 @ 5:04 pm
When you wish to sell you controller call me!!!!
geposted Sun 05 Jun 16 @ 9:59 pm
Thats a great mixer then add an interface could make the price from 350 and up. If it was my decision I would look for midi controls on the mixer, such as the Traktor Z2 599. gives you control and interface built in. Also the DJ-Tech DIF-1M is Good choice at 199-299 is another great choice, But if you have the money the Pioneer DJM-S9 in the best 2channel dvs mixer at this point. 1699 tho...
geposted Mon 06 Jun 16 @ 12:59 am
I couldn't get a feel for the jog wheels. Not like I know the difference since I haven't used turntables either but it just seen too small for my hands. I like the cue point ease of use but just doesn't feel right.
geposted Mon 06 Jun 16 @ 7:18 am
Ok. Lemme figure out my next move with a new setup and if ur still interested, we'll talk.. I'm a truck driver and will be home around the 4th of July and can possibly work something out..
geposted Mon 06 Jun 16 @ 7:21 am
Ok, thanks for the advise. I'll be checking the forums regularly. .
geposted Mon 06 Jun 16 @ 7:26 am
If I go with the xone23c, which has the sound card built in, then I would need to buy the control vinyl and upgrade to vdj pro, correct?
geposted Thu 16 Jun 16 @ 3:31 am
If u still wanna buy the Gemini G4V, lemme know.. the price is $275 firm..
geposted Tue 21 Jun 16 @ 7:10 pm
