VirtualDJ 8.2 ist als Early Access update verfügbar.
Wer die neue Version unverbindlich testen möchte bitte in den Settings/ Optionen "Early Access Update" aktivieren.
Danach V8 nochmals neu starten, und warten bis der Download komplett beendet ist.
geposted Mon 06 Jun 16 @ 1:32 pm
-New skin with customizable PAD pages
-New BPM detection engine
-New BeatGrid detection engine
-New windowing engine, getting look and feel closer together on windows and mac
-Improved action editor with colors and highlighting of if-then-else parts
-Improved touch screen support
-Tag Editor keyboard shortcuts: ALT+LEFT/RIGHT, ALT+SPACE, ALT+ENTER, ALT+W
-Hardware Accelerated video recording (mp4, windows and nvidia only)
-Hardware Accelerated video playback on mac
-Link video to audio file and play linked video without interrupting audio track
-Improved video decoding for sampler and slideshow
-Smarter usage of hardware acceleration for video scratching and looping
-Improved support for WASAPI Exclusive mode
-Improved tag reading: WMA composer tag, MP4 key tag, ID3v2.2 cover art, loop/key info for acid wav
-VST Instrument support: Right-click on midi device (keyboard) in controller options to pass it to VST of a specific deck
-Support for transparent video samples (HAP format)
-Record samples directly to Recordings Bank using 'sampler_rec x' (x is slot number)
-Fix changing existing vdjsample files
-Colored cue points
-Allow silence between mixes in automix by using negative automix fade length
-mix_selected action to mix to selected song in automix
-Fix cracks in automix dualdeck mode
-Karaoke on-screen singer display options
-Export browser view to CSV or HTML
-Ask the DJ: gather audience requests from within the browser (through vdj webpage or twitter)
-browser_zoom support for skins, and implemented in default 2-deck skin
-New audio effect 'Noise'
-More skin options for cue/beatgrid on scratch wave
-Improve quality, memory use and performance of images in video edits
-Improved loopback recording quality
-Colored cue points
geposted Mon 06 Jun 16 @ 1:33 pm
Das hört sich alles sehr gut an =)
eine frage zu:
Muss ich dazu alle Song, neu analysieren lassen?
Viele Grüße Marco
eine frage zu:
Viele Grüße Marco
geposted Mon 06 Jun 16 @ 10:05 pm
ist nicht zwingend erforderlich. Kann aber bei Bedarf gemacht werden.
( Natürlich nicht die ganze Libary auf einmal :-)
geposted Tue 07 Jun 16 @ 5:20 am
Dann wollen wir mal wieder testen ;-)
Feedback folgt
Gruß Lokke
Feedback folgt
Gruß Lokke
geposted Tue 07 Jun 16 @ 5:31 am
Erste Eindrücke:
- Das Pad-Mapping ist ja mal wirklich geil gelöst
- Farbige Cue-Punkte etc. für die skinner einfach gelöst; sehr gut
- Neue Mapping-Engine generell wesentlich besser
- Ask the DJ: Super feature; zumal nicht nur Titelwünsche gesendet werden können
- Browser Zoom endlich wieder standard
Habe eigentlich nichts gefunden (bis auf den St.-Skin), was nicht gefällt.
Ich finde, VDJ hat einen super Job gemacht. Kompliment an die Devs !!!!
geposted Tue 07 Jun 16 @ 5:43 am
Edit: Da ist ein kleiner Fehler drin , Early Access befindet sich hier: Settings/ Optionen / Internet
[... Early Access ist zwar unter dem Überbegriff "Internet" abgelegt, aber i.d.R. wird ja die Suchleiste im Optionsmenue dafür benutzt]
geposted Tue 07 Jun 16 @ 6:56 am
Edit: Oder auch nicht... Zumindest meint das phantomDj.
geposted Tue 07 Jun 16 @ 7:36 am
PachN wrote :ieder werden beim laden neu analysiert wenn sie noch nicht von der neuen engine analysiert wurden. Geht also automatisch.
Also dann alle Songs nochmal neu analysieren lassen? Um sicher zu gehen =)
Ich warte aber ab, bis die 8.2 aus der Beta Phase raus ist und als normales Update kommt.
geposted Tue 07 Jun 16 @ 8:40 am
Hallo ;-)
Ich habe mich getraut und die 8.2 auch installiert. Soweit auch alles schick und die erweiterten Funktionen sind auch prima.... A B E R....
Ich hatte mein Launchpad RGB gemappt...Das Mapping der Befehle ist auch 1 zu 1 übernommen, allerdings funktioniert das LED Feedback nun nicht mehr, komplett dunkel...und das hatte schon einige Arbeit gemacht bei über 70 LED's... ;-(
Und noch schlimmer... die mp4 Videos werden nur noch zerhackelt und verstümmelt wiedergegeben... funktionierte vorher einwandfrei.... Hat jemand ne Idee, insbesondere wegen der Videowiedergabe? Die Settings habe ich geprüft, die sind nicht verändert, alles wie vorher....
Vielen Dank schonmal
geposted Tue 07 Jun 16 @ 9:04 am
Also wenn ich so im englischen Forum lese, scheint es ja bei Videos noch paar Probs zu geben.
Gibt es hier vielleicht schon Erfahrungen ?
geposted Wed 08 Jun 16 @ 7:46 am
Feedback folgt
Gruß Lokke
Feedback folgt
Gruß Lokke
Hallo,
habe mich dann gestern mal ganz mutig an die neue Version gewagt und bisher läuft alles rund.
Werde heute Abend noch mal testen ... auch die Funktion "ask the dj" :-))
Gruß Lokke
geposted Wed 08 Jun 16 @ 12:20 pm
Und mir ist aufgefallen das man seine neu hinzugefügten Titel nicht mehr mit seiner gewählten farbe makieren kann ..
Die ganze Farbscala ist nicht mehr vorhanden..
nur noch 15 Farben zur Auswahl..
..WAS SOLL DAS..
..WAS SOLL DAS..
geposted Wed 08 Jun 16 @ 12:51 pm
Wird wieder geändert. Nur Geduld.
geposted Wed 08 Jun 16 @ 12:54 pm
Prima ..
geposted Wed 08 Jun 16 @ 1:18 pm
Die Funktion "ask the dj" finktioniert auch ... frage mich nur wie ich meinen Gästen diese Information zukommen lassen soll?
Wird also am Ende (leider) wieder eine Funktion sein, die nicht wirklich brauchbar ist als mobiler DJ
geposted Thu 09 Jun 16 @ 5:53 am
Kärtchen an den Tischen z.b. ?
Kann man sich ja auch auf A4 Bögen mit Visitenkartenformat ( z.b. Zweckform ) drucken und verteilen oder bei FB posten .. ect.
geposted Thu 09 Jun 16 @ 6:14 am
Die Funktion ist mit Sicherheit noch ausbaufähig. Ich würde mir wünschen, daß das ask.the.dj
- auf Titelwünsche (gekoppelt an meine DB) beschränkbar wäre
- für jeden Gig ein Passwort datumsbezogen vergeben wird
Dann hätte der Gastgeber z.B. das Brautpaar, die Möglichkeit VOR der Feier spontan einfallende Musikwünsche mitzuteilen. Spam wird vermieden.
Das ganze könnte gefiltert werden, z.B. der gleiche Musikwunsch kann von einem Handy nur einmal abgegeben werden. Die anderen Gäste könnten die Wünsche sehen und voten....und ich hätte eine Playliste, sortiert nach Häufigkeit der Nennungen.
ask bedeutet auch Erwartung von answer...
Ich bin der Meinung, die Gäste wollen den DJ nicht dabei sehen, daß er die ganze Zeit via VDJ "twittert". Der legendäre Ser***o-Blick ist sowieso verpönt. Und ich als DJ möchte nicht Gäste sehen, die die ganze Zeit auf'm I-Phone rumhämmern und dabei das Tanzen vergessen.
Sind nur so meine ganzen Gedanken zum feature....wir werden sehen.
geposted Thu 09 Jun 16 @ 6:50 am
Mein Meinung zum dem Tool "Ask The DJ..." - geht überhaupt nicht. Genau wie Wunschlisten, Karten etc.
Erstens hätte ich gerne den persönlichen Kontakt
Zweitens kann ich dann Antworten (auch mal Nein) und
Drittens lasse ich dann keine unerfüllten Musikwünsche zurück... und damit enttäuschte Gäste, deren Wunsch (warum auch immer) nicht erfüllt/gespielt wurde.....
Weniger ist oft mehr!
geposted Thu 09 Jun 16 @ 7:10 am
ich stehe auf dem Schlauch !! wie geht das mit Ask the DJ ?
geposted Thu 09 Jun 16 @ 7:35 am
