Topic: Custom Buttons Gone?
I can not find the custom buttons I had with VDJ8.1. I see them listed when I open options but can not locate them on the browser. I am using VDJ8 Default 4 Decks...
geposted Tue 07 Jun 16 @ 2:01 am
check in options, skinemptybuttons, select yes, (only for 2 decks)
the new 4 Decks default skin doesnt offer Custom buttons, but you can use the Custom Pad page.
ok Thanks...
