on windows 10 I have installed VDJ wit the hercules MK4 console, what do I need to purchase to work with playlists.
Only home use. (and install the latest version of VDJ)
Regards,
Dirk
Regards,
Dirk
geposted Tue 07 Jun 16 @ 9:11 am
at least you need a plus controler licence to use your MK4
geposted Tue 07 Jun 16 @ 11:37 am
so if I buy the:
VirtualDJ PLUS 'DJCMK4' licence for the discount price off 89$ I get the possibility to use playlists?
Is there any documentation (manual) what the possibilitys are?
sorry I am new with that system I would like to use at home.
Regards,
Dirk
Regards,
Dirk
geposted Tue 07 Jun 16 @ 12:29 pm
found all the info I need.
https://virtualdj.com/products/virtualdj/comparison.html
will buy the PLUS version, will do for my home use.
thanks for helping me.
Regards,
Dirk
Regards,
Dirk
geposted Wed 08 Jun 16 @ 6:34 am
