This is a great example of different BPM recognitions.
It is almost the same track, but different BPMs.
Any clue why?
Well, it doesn't matter if it is half or double value, but still...
Any clue why?
geposted Fri 10 Jun 16 @ 4:46 pm
Did the track have a bpm in the tag before analysing it with vdj?
If so the half/double range from the original tag is preserved.
Edit: Also just checked this particular track. It is easy to count either way, so it is possible that small changes make the algorithm tip over to 130 or 65.
geposted Fri 10 Jun 16 @ 4:49 pm
