I'm having this problem with my Pioneer ddj wego. Fader channel A gone crazy and started jumping whenever i move them. I also had this problem with my previous Hercules RMX controller. The same issue. Usually it happens on my ddj wego when both channel faders are up, then fader A start jumping. Then if I move down fader B it stops doing it but not all the time. The same happens with the crossfader. Please some help. Thank you very much.
I already tried reinstallign drivers and updating firmware.
geposted Fri 10 Jun 16 @ 6:37 pm
Hey Reigar,
what do you mean by jumping?
what build are you using?
PC or Mac?
regards
ray
PC or Mac?
regards
ray
geposted Fri 10 Jun 16 @ 9:10 pm
What you describe is definitely a Hardware fault. Probably some dust on the contacts. Please consult a Pioneer tech agent for options.
geposted Fri 10 Jun 16 @ 11:52 pm
Yes it is, already solved it myself. I cleaned the faders with alcohol and did some tweaking on it.
For those with this problem, do the same. Just clean the faders but you have to take it all apart and must be very careful.
Please close this thread.
geposted Sat 11 Jun 16 @ 6:14 pm
As you wish.
LOCKED BY AMAHM
LOCKED BY AMAHM
geposted Sat 18 Jun 16 @ 12:59 am
