ever since 8.2 the button on my controller mapper to "mic" defaults to on when i load things up any way to get that reversed and default to off
thanks.
thanks.
geposted Sat 11 Jun 16 @ 4:44 pm
Which controller is that ?
And which button of this controller is assigned as "mic" ?
geposted Sun 12 Jun 16 @ 10:25 am
pioneer DDJ-Ergo
button is vid_trans_active
since i rarely do video its a good button for me been using it for a few years now.
geposted Sun 12 Jun 16 @ 11:48 am
Anyone?
geposted Mon 13 Jun 16 @ 2:51 pm
So if both Keys VID_TRANS_ACTIVE and LED_VID_TRANS_ACTIVE are mapped as mic, close VirtualDJ and re-open, the Led of the button is On ?
geposted Mon 13 Jun 16 @ 3:24 pm
Yes and mic is active
geposted Mon 13 Jun 16 @ 4:39 pm
Try to assign a custom button on your skin as mic and see if it lights up when you launch VirtualDJ.
If Mic is added to the Audio setup, it shouldnt enable it by default.
Maybe there is some action to the ONINIT of your controller/keyboard/skin that enables Mic on launch ??
geposted Mon 13 Jun 16 @ 4:50 pm
oh i see...
Since the Ergo doesnt have a MIC On/Off button, the Mic Volume knob was mapped to turn on the Mic if its position greater than zero..
param_smaller 1% ? mic off & mic_volume : mic on & mic_volume
So in case you need to have a button to turn mic on, you will also need to assign the MIC VOL key as mic_volume instead of the action above.
But weird that this wasnt happening with 8.1 as well, unless you have recently added the mic action to the new button.
geposted Mon 13 Jun 16 @ 5:36 pm
thanks that is what i will do .. much appreciated
geposted Mon 13 Jun 16 @ 6:58 pm
can someone help me get a mic to work on a korg kaoss dj controller using the 1/4 inch mic input on the controller? thanks anyone
geposted Mon 29 Aug 16 @ 9:31 pm
