When I play song sometimes it will jump into the middle of the song for example I press play but it jumps like 30 secs into the song.
geposted Sun 12 Jun 16 @ 4:19 am
Check your "AutoCue" setting (Settings - Options).
If it is 'First Beat' change to another option.
geposted Sun 12 Jun 16 @ 5:34 am
It was set to cue thats the weird thing about it. It will do it like every 5 songs. Just jump into the middle of the song. I switched to skip silence.
geposted Sun 12 Jun 16 @ 5:14 pm
Next time it occurs please check (just in case) if you have SLIP enabled.
geposted Sun 12 Jun 16 @ 6:32 pm
It's still doing it. When I load a song about every 5 songs it will jump into a random part of the song instead from the beginning. yes I changed the auto cue from first beat and my slip isn't enabled. I think its the software. And I just updated to 8.2 but it has been doing this since 8.1. I wonder if it's a RAM issue ?
geposted Mon 13 Jun 16 @ 9:52 pm
What is "smart play" set at? Where are these songs acquired from? Do these songs have cue points set?
geposted Fri 17 Jun 16 @ 11:10 pm
