How do you delete keyboard mapping in 8.2? That is if you want to change to a different letter?
geposted Mon 13 Jun 16 @ 3:34 pm
Also how to ADD new keyboard shortcut
geposted Mon 13 Jun 16 @ 4:09 pm
You can delete any custom mapping by selecting the mapping from the top-right drop-down menu and then hit the X button on the right side.
If you just wish to edit a mapping (custom or default), you chose the mapping file from the menu, and either select the Key you want to change from the left-side list or click inside the Key box and hit the keyboard button.
If you edit the factory default, a new custom mapping will be generated automatically.
If you edit a custom mapping, it will be saved with the same name with all the previous edits.
If you want to delete a Key from a mapping, you select the key and delete its action.
geposted Mon 13 Jun 16 @ 4:17 pm
