Posted this in the Facebook forum and wanted to post this here.
At a wedding last night, latest early access of 8.2, (which was 3217 as I hadn't yet seen 3236) with the cocktail music in automix, suddenly the software disconnected and reconnected to my controller (Denon MC6000mk2) and then froze. Shut down the software started it up again froze again. Restarted computer everything is okay now. Anyone else have this issue?
Before you flame me for using an early access build at a public event, I had tested everything with build 3217 prior to an event on Thursday and a wedding on Saturday. Even ran the ceremony on a second laptop with 3217 and no issues.
This is the first crash I've ever had. Was not online and did not use Ask The DJ. I would want to test Ask The DJ at home first.
geposted Mon 13 Jun 16 @ 4:26 pm
John a lot of fixes got done with 3236 and more are on there way...
geposted Tue 14 Jun 16 @ 1:27 am
I'm also having problems with 8.2. I updated to 8.2, and used it on Pioneer CDJ 900's. The firmware is up to date on the 900s and also downloaded the new pioneer cdj 900 drivers. After playing for 30 min with the 900's plugged directly into my laptop using printer cables, the program stops working, closes down and re-opens. I have to reboot the machine and re-connect to the cdj's. Also what happens with 8.2, the song will play and the wave length shows the song, but while its playing, it runs through the song and carry's on playing, even though virtual shows the song is finished.
I also have an Pioneer SX2 controller and have no issues using version 8.2.
I have gone back 4 builds to use with the 900's, and been fine so far.
Just if you have a pro license, you want to use the latest build.
geposted Thu 05 Jan 17 @ 9:09 am
