In the latest build (3236), I can't browse for the folder I want to use in the Slideshow anymore. When I click the button to select the path, the explorer window doesn't open like it used to (and as it should).
geposted Tue 14 Jun 16 @ 11:30 pm
Yep, can confirm, noticed this the other day but just thought it was me being a dumb ass, probably still holds true anyways.
geposted Wed 15 Jun 16 @ 12:04 am
aaaaargh! confirmed here too :(
its one of the most used features, to be able to re-select the photos directories..
at the moment I'm stuck at desktop\New Folder
geposted Wed 15 Jun 16 @ 12:44 am
There's a way around it... Go to your Documents folder, then VirtualdJ > Plugins and edit the native_slideshow.ini file manually...
But this is not how it's supposed to work...
geposted Wed 15 Jun 16 @ 12:47 am
it's been reported more than 2-3 days ago.
geposted Wed 15 Jun 16 @ 1:09 am
Hi edit it with what?
geposted Wed 15 Jun 16 @ 6:58 pm
Notepad++
geposted Wed 15 Jun 16 @ 7:07 pm
if you can't wait for the fixed version, then do the work around.
Notepad or any text editor then change the String Path to what ever the Path of the folder.
In windows, just double click on the native_Slideshow.ini to edit or use notepad.
geposted Wed 15 Jun 16 @ 7:08 pm
do you have an example as I cant seem to get it right :(
Ive accidentally corrupted the file can someone a copy of it on here please
geposted Wed 15 Jun 16 @ 7:16 pm
[autoparams]
Slider Speed 1=2048
Slider Fade 2=1365
Switch Shuffle 4=0
Switch Video 5=0
String Path 3=C:\Users\MarkD\Desktop\New folder (2)\
if i edit this, will i have to re-open vdj?? :(
Might just be quicker to change the files in the folder its pointing to.
Slider Speed 1=2048
Slider Fade 2=1365
Switch Shuffle 4=0
Switch Video 5=0
geposted Wed 15 Jun 16 @ 8:43 pm
just use an older version, set it up the you want then back again.
geposted Wed 15 Jun 16 @ 10:32 pm
marksmolinski wrote :
[autoparams]
Slider Speed 1=2048
Slider Fade 2=1365
Switch Shuffle 4=0
Switch Video 5=0
Slider Speed 1=2048
Slider Fade 2=1365
Switch Shuffle 4=0
Switch Video 5=0
Thanks works perfectly now
geposted Thu 16 Jun 16 @ 7:16 am
fixed in the Early access b3268.
https://virtualdj.com/download/build.html
geposted Mon 20 Jun 16 @ 2:24 pm
