Recieved a numark mix track 3 as a gift i plugged it in and all that good stuff and got the sabrent sound card from Amazon why can I not cue anything through headphones to cue songs everything I play comes across the phones and speakers I literally have tried everything any ideas?
geposted Sun 19 Jun 16 @ 12:25 pm
Hello, it seems from your profile that you are a home user, if you upgrade to VDJ 8 Pro the software will automatically map to your controller and you would be good to go.
geposted Sun 19 Jun 16 @ 12:40 pm
My pro trial is unlocked am I still limited?
geposted Sun 19 Jun 16 @ 12:44 pm
The only thing buying pro would do is unlock the controller for use over 10 minutes.
It will not change anything to what is available in settings otherwise.
It is probably easiest if you posted a screenshot of your audio configuration.
The sabrent appears to have only one output which is not the most optimal choice for use with master/headphones setup, but it should still work.
Master should be configured to go to your internal sound card, headphones should be configured to use the sabrent. (or vice versa)
geposted Sun 19 Jun 16 @ 12:47 pm
Sabrent has the microphone port and then the audio port do you want the picture of how it's set up or like the settings menu
geposted Sun 19 Jun 16 @ 1:00 pm
Yes, and perhaps also describe where you have plugged in your headphones, and where you have plugged in your speakers.
A microphone is an input port, you can plug in a microphone, but it has no use to plug in speakers or head phones.
geposted Sun 19 Jun 16 @ 1:29 pm
I was using computer speakers with that sound card and then had my headphones aligned with the usb output device
geposted Sun 19 Jun 16 @ 1:46 pm
Assuming that you need to have Master Output from your computer's built-in speakers and prelistening from a USB Sound card, you will need to follow the Audio configuration described in the manual
https://virtualdj.com/documents/Manuals/VirtualDJ8_User_Guide.pdf
Chapter : Audio Setup with Speakers (Master) & Headphones (prelisten)
- Page 90-91
In case you still have issues please post the following screenshots :
- Audio Setup from VirtualDJ Settings (AUDIO tab)
- Playback (devices) tab of Windows Sound
- Page 90-91
geposted Sun 19 Jun 16 @ 1:56 pm
I don't understand why this will not work I have a sound card(sabrent) a splitter cable beats headphones and a mix track 3 using a line in line out to a jbl speaker running virtual dj everytime I try to cue headphones and not hear over speakers it's never headphone isolated tried everything please help ?
geposted Mon 20 Jun 16 @ 5:10 am
What are your audio settings now?
geposted Mon 20 Jun 16 @ 6:26 am
I have used pretty much all of them with splitter and audio chord I need like step by step help I have done everything from two sound cards to splitter
geposted Mon 20 Jun 16 @ 6:41 am
We have provided link to our manual which explains in detail on how to connect speakers/headphones and how the Audio setup in VirtualDJ should be.
As far as i can tell, you have an external Single Stereo USB Sound card, the built-in sound card of your computer and a pair of Speakers.
The best case would be to connect your Headphones to the Output of the USB sound card and then connect your external speakers to the Sound Output of your computer.
In this case , you dont need any Splitter cable/adapter , and the Audio Setup should be ..
Master ..... Your Computer's builtin sound cards ... Chans 1,2
Headphones... The USB Sound card ............ Chans 1,2
Isnt this working for you ?
geposted Mon 20 Jun 16 @ 3:15 pm
