Hey Fellow VDJ Users,
Got a couple of questions for you pro infinity users.
So I am looking to take the leap of faith and upgrade to pro infinity, what I would like to know is... 1, How easy is it to swap controllers if you have multiple controllers... 2, Has anyone had experience in maybe using the controller at a party and you've had to swap the controller there and then due to some type of failure, and does pro infinity allow you to change without any hassle?
Thanks in advance!
Thanks in advance!
geposted Wed 22 Jun 16 @ 8:07 pm
All supported controllers are just plug & play. Therefore swaping controller is as easy as connecting new controller, opening settings, applying new sound profile (since most controllers have their own sound interface), closing settings, play!
geposted Wed 22 Jun 16 @ 8:11 pm
The simple answer is yes, you can use any supported controller, and change whenever you want. It is better to set up your controllers at home, and save any commands you have created. This way VDJ will recognize them when ever they are connected.
You can also have multiple controllers connected at the same time. I am using the MC6000 and LaunchpadS together.
geposted Wed 22 Jun 16 @ 8:13 pm
Appreciate the quick response.
If you have two different controllers and your have to load two different drivers on the one laptop, has any of you guys had an issue where the drivers start to conflict with each other?
geposted Wed 22 Jun 16 @ 8:17 pm
No, because the computer and software are working together.
geposted Wed 22 Jun 16 @ 8:21 pm
Conflicting drivers are a very rare case.
I have about 20 different device drivers installed on my system (since I'm a hardware developer) and all of them work without issues with VirtualDj.
geposted Wed 22 Jun 16 @ 8:23 pm
What type of controllers are you two using - PhantomDeejay and A Man and his music?
geposted Thu 23 Jun 16 @ 7:40 am
Could just add a little info on my setup, while the subject is multiple controllers.
Using Denon MC6000 Mk1 together with AKAI MPC mini, Traktor Kontrol F1, and a Traktor Kontrol X1 Mk2 , it all seems very stable.
geposted Thu 23 Jun 16 @ 9:07 am
On the club I use Pioneer DDJ-SZ, DDJ-SP1 and Traktor Kontrol F1 at the same time.
On my laptop (for mobile gigs) I use DDJ-SX2 among DDJ-SP1
On my studio PC I use various combinations of gear.
My studio PC has these drivers installed as we speak:
Pioneer DDJ-SZ
Pioneer DDJ-SX2
Pioneer DDJ-SX
Pioneer DJM-900SRT
Pioneer XDJ-1000
Pioneer DDJ-WeGO3
Denon MC6000MK2
Hercules RMX2
Hercules JogVision
Traktor Kontrol F1
Traktor Kontrol Z2
Traktor Kontrol S8
Traktor Kontrol X1MK2
Gemini G4V
Gemini G2V
Akai AMX
... and a few others... :P
Pioneer DDJ-SZ
Pioneer DDJ-SX2
Pioneer DDJ-SX
Pioneer DJM-900SRT
Pioneer XDJ-1000
Pioneer DDJ-WeGO3
Denon MC6000MK2
Hercules RMX2
Hercules JogVision
Traktor Kontrol F1
Traktor Kontrol Z2
Traktor Kontrol S8
Gemini G4V
Gemini G2V
Akai AMX
geposted Thu 23 Jun 16 @ 9:33 am
OK
My Contribution.....
Pioneer DDJ -SX
Reloop Neon
Mixtrack Pro
and all can be used at the same time
Pioneer SX ---Deck 1&2
Mixtrack Pro ----Deck 3&4
hahahahah loving it
(monthly based pro subscriber)
Pioneer DDJ -SX
Reloop Neon
Mixtrack Pro
hahahahah loving it
geposted Thu 23 Jun 16 @ 12:44 pm
At the moment, MC6000 and LaunchPadS. I also have a RMX 1000, but I am presently using as a hardware controller. If I find a reason to use as a VST, I will.
geposted Thu 23 Jun 16 @ 6:07 pm
Pioneer sx seems to be a very popular controller, Ill check it out in my nearest store.
Thanks for the feedback!
geposted Thu 23 Jun 16 @ 6:17 pm
You may want go look at the SX2, which have the added features.
geposted Thu 23 Jun 16 @ 6:19 pm
Forgot to say, I am going ahead with the upgrade.
Once done this shouldn't affect my layout or setting that I already have. Last thing I wanna do is lose my folders and whatever..
geposted Thu 23 Jun 16 @ 6:20 pm
