I have two DJ aliases, both with very different music styles and each with its own skin. Is it possible to make the settings local to each skin?
For example, with one DJ I do not want covers to show, but with the other I do.
geposted Fri 01 Jul 16 @ 12:23 pm
Usually skin settings are stored as global variables inside settings.xml file
So, your best shot would be to make 2 copies of settings.xml file, one for each "profile"
geposted Fri 01 Jul 16 @ 12:54 pm
Sound like a solution. Could you be a bit more specific? How do I do this?
geposted Fri 01 Jul 16 @ 3:33 pm
There's a profile switcher add on that makes this easy
geposted Fri 01 Jul 16 @ 3:48 pm
Great!
I found it: VDJ 8 Profiles By Djsadim.
Thanks Adion :)
Thanks Adion :)
geposted Fri 01 Jul 16 @ 5:16 pm
