Hi can you guys help me how active this visualisation,or any video how to active this im on mac,but I have no clue !!!!!
Thanks.
Thanks.
geposted Sun 03 Jul 16 @ 8:44 am
No clue?
geposted Mon 04 Jul 16 @ 5:05 am
It's a very simple plugin - what problem are you having with it exactly?
geposted Mon 04 Jul 16 @ 8:55 am
Ok ,when im activing this nothing happens, so I dont know how do it...
geposted Mon 04 Jul 16 @ 9:55 pm
Do you know what Syphon is?
SyphonClient allows you to route video from an external application (that has Syphon support) into VDJ. This means you must have that other application set up and sending video via Syphon, otherwise the plugin won't do anything.
geposted Mon 04 Jul 16 @ 10:21 pm
Ok thank you for explanation....so now Im gonna look for that o somebody who can help me to put this to work?
geposted Tue 05 Jul 16 @ 7:25 am
Well you need to set up amother application - like Resolume - to send it's video via Syphon.
Once you've done that then the plugin will receive that video.
This is something you have to actually have a use for ;)
geposted Tue 05 Jul 16 @ 11:53 am
Solve thanks!!!!
geposted Mon 11 Jul 16 @ 5:31 am
hello i use google Traductio to write you this message.
is there an addon like SYPHON but PC because I use virtual dj ARKAOS and if not how is it possible to do this.
Thank you.
Francky108
Thank you.
Francky108
geposted Thu 11 Aug 16 @ 6:08 am
Google "Spout"
It will or should do the same as syphon but on a PC. I will say this, you better have a powerful machine or else you can forget about doing this, lol!
geposted Thu 11 Aug 16 @ 3:29 pm
Heres a video I made awhile back showing how I use Syphon
I've since changed a few things but this should get you rolling.
Hope it helps.
geposted Wed 24 Aug 16 @ 2:32 am
