Hi,
I'd like to map a button on my denon mc4000 so I can easily navigate backward/forward through my track (4 beats step)
Is there away I can do this pls ? Thanks
geposted Mon 04 Jul 16 @ 3:33 pm
I also can't figure out how the denon mc4000 fx work. I press the fx on/select but nothing happen. If anyone can pls tell me how this work. thanks.
geposted Mon 04 Jul 16 @ 3:42 pm
For the beats you can use the commands move +4 & move -4
MC4000 guide here, see section F:
https://virtualdj.com/documents/Denon%20MC4000%20-%20VirtualDJ%208%20Operation%20Guide.pdf
geposted Mon 04 Jul 16 @ 3:49 pm
Thanks!
geposted Mon 04 Jul 16 @ 5:09 pm
I assigned no. 1 & 2 on my keyboard to move +4 & move -4 but nothing's happening. help!
geposted Mon 04 Jul 16 @ 5:40 pm
If it is on the keyboard rather than a controller you would need to add the deck number beforehand, or deck left & right if you are only using a two deck configuration. On a controller the sides are defined but the keyboard needs to know which deck you are applying the command to.
If move doesn't work you could try goto instead.
For example deck left goto +4
Or if you want the beats to move on the active deck, you could try deck active goto +4
geposted Mon 04 Jul 16 @ 5:42 pm
Shift+Tap changes the fx mode from all the knobs controlling one effect... to each button/knob combo each controlling a single effect.
In the shift+tab mode, holding shift down will allow you to control the second parameter.
geposted Tue 05 Jul 16 @ 12:43 pm
Thanks guys! Im all good now :-)
geposted Wed 06 Jul 16 @ 12:28 pm
Does the Denon MC4000 work with Virtual the latest version on VDJ 7?
geposted Fri 23 Sep 16 @ 7:25 pm
VDJ 7? is not the latest
geposted Fri 23 Sep 16 @ 7:34 pm
No, requires version 8
geposted Fri 23 Sep 16 @ 9:27 pm
I'm loving my Denon mc4000, so flawless with virtual dj 8, no glitches, brilliant! :D
Now I need a power adapter as i like to carry a spare. Does anyone know or can post a link where i can get one ? thanks :)
geposted Sat 01 Oct 16 @ 8:02 am
Never looked into it but I suppose you could just call Denon up themselves and order one straight from them....
geposted Sun 02 Oct 16 @ 12:10 pm
From what I remember it's a 6v 3a centre positive DC supply.
geposted Sun 02 Oct 16 @ 12:50 pm
back of the unit says 5volt 3 amp center positive
geposted Sun 02 Oct 16 @ 1:32 pm
Thanks guys, I'll order it from denon to be on the safe side :)
geposted Wed 05 Oct 16 @ 2:17 pm
Please update because an extra power supply do comes in handy.
geposted Wed 05 Oct 16 @ 3:19 pm
